Радар-детектор Street Storm STR-9900EX GL c ГЛОНАСС/GPS модулем
DeathMan
SS F1 SOCHI Z и SS 9540SE
Opel Meriva A
@_СаНёК_очень странно действительно, ОЧЕНЬ запутать народ походу хотят
Super Rain Man
STR-9540BT
Chrysler 300
Hello Dear Forum Members !
Now, "Old STR-9900EX GL (Non-Signature Version)" can work with OTG (USB On-The-Go) feature. To work with your smartphone, please kindly take following steps:
1. Please kindly disconnect power cord from the radar detector, before OTG-Updating. ***
(In other words, please kindly proceed "OTG-update", using Smartphone power only).
2. Please kindly note that "Street Storm BLE App” should be updated to the latest version v.3.2.
If it does not work with your unit or with your smartphone after the steps above, please kindly report the problem. And, we will check the symptoms.
Thank you very much !
*** VERY VERY IMPORTANT !
Сергей115
УрФО
StreetStorm STR-9540ВТ
Kia Sorento Prime
@Super Rain Man
Не работает OTG-обновление баз GPS на SS STR-9900EX GL (Non-Signature Version). SS BLE обновлена до v3.2., пробовал на двух смартфонах: Highscreen power five pro (андроид 5.0) и Highscreen power five evo (андроид 5.1). При подключении РД проводом к смартфону запускается SS BLE, но при нажатии кнопки "соединить" SS BLE зависает и ничего больше не происходит. Через ноутбук всё обновляется нормально.
Super Rain Man
STR-9540BT
Chrysler 300
Hello Dear @Сергей115,
Thank you very much for your report. It is my great regret that you cannot use USB-OTG feature for your STR-9900EX GL.
1. From my dimmed memory, you also had same issue with your STR-9540BT, right? Was the issue resolved now?
2. Unfortunately, we still could not test any of Highscreen brand smartphone yet. According to the user's report, Xiaomi, ASUS, Samsung, and LG are working with our OTG feature, so far.
3. By the way, have you had chance to try with other brands, except Highscreen? For example, if Xiaomi or Samsung too is not working with your STR-9900EX GL, then there could be something wrong with your STR-9900EX GL.
Best regards.
* p.s : Please kindly understand that I will need to prepare for CES 2018 and so my response could be delayed without advance notice (http://www.streetstorm.ru/blog/street_storm_na_vystavke_ces_2018/). Thank you very much for your kind patience.
Important Notification:
Before OTG updating, please make sure of disconnecting power cord from the radar detector.
(That is, please kindly proceed "OTG-update", using Smartphone power only).
Сергей115
УрФО
Kia Sorento Prime
Добрый день @Super Rain Man,
У меня есть оба РД: и STR-9540ВТ и STR-9900EX GL. С выше указанными смартфонами Highscreen OTG-обновление не работает на обоих радар-детекторах, SS BLE v3.2 зависает на моменте нажатия кнопки "соединить". Так же я пробовал обновлять РД с помощью планшета Lenovo(андроид 4.4), не работает. Со смартфоном Samsung(андроид 6.0) обновить STR-9540BT через OTG получилось, STR-9900EX GL через этот смартфон попробовать обновить пока нет возможности. Думаю проблема в совместимости со смартфонами Highscreen и Lenovo. Надеюсь у Вас получится решить данную проблему, так как менять смартфон в ближайшее время не собираюсь.
Nikolay
StreetStorm
Street Storm STR-9540BT
Здравствуйте, Сергей115! Извините за задержку с ответом! На выставке инженеры были. Приняли к сведению, над расширением совместимости работы с разными смартфонами работаем.
badboy2115
SS STR-9570PRO (fw:211027)
LADA
rasul1988
