Street Storm STR-9900EX
DeathMan
SS F1 SOCHI Z и SS 9540SE
Opel Meriva A
Крис-П в спину, отработка что надо, понравилось, метров за 200-300, режим супер тихий
oleum944
Neoline 8700s, 7500s
Subaru Forester
@DeathMan
А как понять где радар?
Randy44
STR-9540BT
kia rio
Еще раз проверил, включил Ограничение = 50 км и снова у меня не включаются режимы Г1, 2, 3 только Трасса и СуперТихий
@DeathMan , снимите, пожалуйста, видео как это выглядит, а заодно бы прощёлкать по пунктам меню. Интересно, там всё стандартно? Да, после обновления РД, выполнялся сброс в заводские настройки?
Super Rain Man
STR-9540BT
Chrysler 300
Hello Dear @waycat!
Thank you very much for your tests. I will review your test results and let you know, if any.
I will also let you know about the 2nd sample, after fully discussing with our development team.
Using this chance, I would like to update two items about STR-9900EX model as follows.
We have two kinds of AUTO Features. One is Auto Brightness and the other is Auto Time.
1. AUTO Brightness Adjustment Feature (We found a software bug and fixed it today)
There are 4 kinds of brightness adjustment levels in Display: (1) AUTO, (2) BRIGHT, (3) DIM, and (4) DARK.
And, AUTO means that it automatically changes between BRIGHT and DIM based on local time (see table below).
For example, when you look at November below, it is automatically set as BRIGHT mode during 07:00-16:00, but it will be automatically changed to DIM mode before 07:00 and after 16:00. To simply put, it is BRIGHT during daytime and becomes DIM at nighttime.
08:00 - 16:00 : January
07:00 - 17:00 : February
07:00 - 18:00 : March
06:00 - 18:00 : April
06:00 - 19:00 : May
05:00 - 20:00 : June
05:00 - 20:00 : July
06:00 - 19:00 : August
06:00 - 18:00 : September
07:00 - 17:00 : October
07:00 - 16:00 : November
08:00 - 16:00 : December
Our recommendation is to drive with AUTO mode in normal situation. If the table above is changed, users can download new firmware (i.e. We released Firmware 0003 today).
2. AUTO Time Adjustment Feature
STR-9900EX also has auto time feature. Therefore, when a customer buys STR-9900EX, he or she does not have to manually adjust local time. STR-9900EX will simply recognize and automatically adjust local time in anywhere in the world.
For example, if you travel to Germany and turn on STR-9900EX, it will automatically change to local time in Germany.
In some special occasions (i.e. summer time), however, it is possible that it will not recognize changed summer time immediately. In this case, users need to adjust local time manually or download new firmware.
waycat
Калуга
Sho-Me G-1000 Signature
VW Touareg
@Super Rain Man, thank you!
It is in our common interests to make this product better.
Installed today this new firmware. Did it with phone via OTG. Installed without problems. Then did the control connection/disconnection of 9900EX to be determined correctly.
False positives on the "Kordon" and left. And, as I wrote, very similar to the response signal of the side assist radar (SAR) of the car, because it happens mostly when the machine is in cramped conditions - check in the garage, backyard (though sometimes even simply drive up to the closed gate a couple of meters), laterally long is a bus/lorry, or a long row of parked cars... And what I noticed when leaving the garage / leaving from work reactions is no, and when they come there. Today checked - entered the garage to the accompaniment of triggering full-scale "Kordon", when it was inside (9900EX didn't stop), turned off/turned on the 9900EX - response "Kordon" no. Thus, when the device is turned in a strong background of triggering SAR it gives no response, but in the process, triggered by his strong increase.
Установил сегодня новую прошивку. Делал это с телефона, посредством OTG. Установилась без проблем. После этого сделал контрольное отключение/подключение РД к телефону - определяется корректно.
Ложные срабатывания на "Кордон" так и остались. Причём, как я уже писал, очень похоже на срабатывание на сигнал собственных ДМЗ машины, т.к. это происходит в основном когда машина находится в стеснённых условиях - заезд в гараж, тесный двор (хотя иногда уже даже достаточно просто подъехать к закрытым воротам на пару метров), сбоку долго находится автобус/грузовик, либо длинный ряд припаркованных машин... Причём, на что ещё обратил внимание - когда выезжаю из гаража / уезжаю с работы - сработок нет, а когда приезжаю - есть. Сегодня проверил следующее - заехал в гараж под аккомпанемент сработки на полную шкалу на "Кордон", уже находясь внутри (РД не умолкал), выключил/включил РД - сработки нет. Т.е. получается, что при включении в условиях сильного фона ДМЗ он сработки не даёт, но в процессе работы срабатывает на его сильное увеличении.
DeathMan
Opel Meriva A
п.12 Правил
попробую[DOUBLEPOST=1511973675][/DOUBLEPOST]
а че уже новая вышла, а от куда это можно узнать что новая вышла ?[DOUBLEPOST=1511974113][/DOUBLEPOST]Кстати, РД отлично справляется с наводками, там где SilverStone Monaco S и Supra DRS-SG171V давали ложные срабатывания
waycat
Калуга
VW Touareg
V1 Monaco S Sochi Z EVO S
Kia
Кино покажите где Супра и Монако срабатывают на ложные, а Стрит молчит? сравниваете надеюсь чисто сигнатурные режимы или в Трассе?
@DeathMan
Я вот смотрю у вас такой большой опыт владения различными РД, а рассуждаете как будь-то первый раз радар-детектор приобрели.
С какими наводками, поясните ?
DeathMan
Opel Meriva A
Монако уже продан, вместо него куплен 9900EX, а вот Supra лежит и в любой момент может быть подключена. Катал только в сигнатурных режимах, ради них все и покупалось.
Кстати, по работе GPS (скорость обновления скорости движения и точность), пока лидер SilverStone F1 MONACO (S) у него самое четкое (если сравнивать со спидометром) и скоростное обновление данных
[DOUBLEPOST=1511977091][/DOUBLEPOST]
Я вас не понимать
Kia
@DeathMan, тогда ждём от вас видео, потому как лично имею и Сигнатурный Стрит и Монако С (и я не один такой на форуме), Супру 171 не катал, но катал 177-ю, и в плане сравнения режимов СТР и ГОРОД2 и ТИХИЙ скажу вам, что НЕ ВЕРЮ вашим словам! Потому как того что вы описывает не может быть.
@DeathMan, ну и что бы мои слова не были только словами, как у вас, немного видео
со Стритом видео нет (но могу в любой момент сделать), но на словах скажу, что Стрит 9530 BT в режиме СТР срабатывает в К-диапазоне
Super Rain Man
STR-9540BT
Chrysler 300
Hello Dear @waycat!
Thank you for your tests again. It is pleasant to know that you could update new firmware (0003) with your smartphone via OTG.
Could you please let me know about your smartphone?
- Brand Name:
- Model Number:
- Android Version:
Thank you very much!
DeathMan
Opel Meriva A
В субботу катался под дождем, заезд в спину Крис-П, результат печальный, залет 100% был бы, сигнал пошел за 50 метров до радара, режим Супер Тихий
investigator
KIA
Хочу спросить у опытных . В 9900 ЕХ после выключения и последующего включения питания Пользовательские настройки сохраняются ВСЕ, за исключением Диапазона Х, который вновь включается, несмотря на то, что я его отключаю и выхожу из Меню по всем правилам - убрал галку кнопкой CITY и вышел кнопкой PROG. Что можно предпринять? Прошивается/перепрошивается успешно и от компа и от телефона. Версия ПО GPS-Бд: 9900ЕХ1512170004. Сброс к заводским делал и до и после прошивки. Постоянно включенный Х диапазон мне совсем не нужен:(
waycat
Калуга
VW Touareg
@investigator, кстати да, получается что имело место такое быть.
По 0004 подробнее не скажу (так как давно не обновлял РД), проверил сначала на версии прошивки 0003 там такое же было и со "Стрелкой" и с "Диапазоном К". Обновился, прошивка встала уже 0005 - теперь вроде всё работает корректно. Так что обновитесь.
Кстати, @Nikolay, @Super Rain Man, получается что за прошедшие три недели прошивка обновилась уже дважды, а в профильной ветке по устройству никакой информации на эту тему нет, т.е. опять пользователи предоставлены сами себе:
А так, в основном узнаётся самопроизвольно, по мере обновления баз. :)
@investigator, by the way, Yes, it turns out that there has been such to be.
Custom settings are saved, ALL except for the Range X
By 0004 I dont now (since I didn't update RD), first tested on firmware version 0003 is the same was and with "Стрелка" and "Диапазон К". Updated the firmware, it's up 0005 - now it seems everything is working correctly. So update.
By the way, @Nikolay, @Super Rain Man, it turns out that for the past three weeks the firmware has been updated twice already, and in a profile branch on the device, no information on the subject, not ie again users are left to themselves:
And so, basically recognized spontaneously, as updates. :)
Nikolay
StreetStorm
Street Storm STR-9540BT
Здравствуйте!
Уважаемые Investigator и Waycat! Приносим извинения за задержку! ПО для STR-9900EX обновлено, анонсируем спустя пару дней, так как пока не готово видео, которые обычно стараемся к анонсу прикладывать. Видео на днях добавим.
Касательно сохранения настроек ошибку исправили.
Кроме того, по работе в целом добавлены расширения голосовых оповещений в тех местах, где они требуются (выделенная полоса, в спину, перекрёсток, начало и конец зоны контроля).
waycat
Калуга
VW Touareg
Добрый день, @Nikolay. Спасибо за пояснения. Но всё равно получается что как минимум об одном обновлении прошивки оповестить вы просто забыли (или не стали). Т.к. по состоянию на 29.11.2017г. была версия 0003, сегодня загрузилась уже версия 0005, а у @investigator была версия 0004 (загруженная в районе 15.12.2017г., судя по дате его баз).
for STR-9900EX updated, we announce after a couple of days until ready videos, which usually try to the announcement to make.
Good afternoon, @Nikolay. Thanks for the clarification. But still it turns out that at least one firmware update to inform you just forgot (or did not). Because as 29.11.2017 was version 0003, today, already loaded version 0005, and @investigator was the version 0004 (loaded in the area 15.12.2017 G., judging from the date of its bases).
waycat
Калуга
VW Touareg
Проехался сегодня с прошивкой 0005.
По "Кордонам" ситуация не изменилась (в спину только по проезду).
Получил ещё одно подтверждение "заглядывания в базу".
У нас стоят два "Криса" которые по базам числятся "Аренами". На подъезде к одному из них РД сначала издалека поймал радарный сигнал и обозвал "Ареной", а уже вблизи переправился на "Крис".
Кстати, внесли изменение в озвучку (но кривовато). Теперь вместо "Крис П" говорит просто "Крис" (но чувствуется что фразу не перезаписывали, а просто обрезали, поэтому звучит не очень), хотя на экране по прежнему пишет "Крис П".
Прикладываю пару роликов (изначально снимать не собирался, поэтому sorry за качество).
Rode today with firmware 0005.
"Cordons" the situation has not changed (in the back only for us).
Received another confirmation of "looking into the base".
We are two "КРИС" which bases the number of "Арена". At the entrance to one of them from a distance unit first caught the radar signal and called me a "Арена", and close crossed to "КРИС".
By the way, made a change in voice acting (but crooked). Now, instead of "КРИС П" just says "КРИС" (but I feel that the phrase does not overwrite, but just cut off, so that's not very), although the screen still "КРИС П".
Freebfb
