AXPER Combo Hybrid
proskurnin
AXPER Combo Hybrid 2CH Wi-Fi
Kia Cerato Kuop
Всем привет!
GPS заработал. Как-то сам заработал.
НО ... Теперь не стартует запись видео, после старта регистратора.
В логах есть ошибки.
Первый блок ошибок:
Код:
Power On Sequence = Safe
ERR:ramdsk_setParam() No Implement! uiEvt 2
ERR:ramdsk_setParam() No Implement! uiEvt 1
Второй блок ошибок:
Код:
ERR:dsi_setConfig() PLL11 = 0x280000
[0]Low power Cmd => 0x11
[1]Low power Cmd => 0xff
[0]Low power Cmd => 0xef
[1]Low power Cmd => 0xc0
[1]Low power Cmd => 0xc1
[1]Low power Cmd => 0xc2
[0]Low power Cmd => 0xcc
[1]Low power Cmd => 0xb0
[1]Low power Cmd => 0xb1
[0]Low power Cmd => 0xb0
[0]Low power Cmd => 0xb1
[0]Low power Cmd => 0xb2
[0]Low power Cmd => 0xb3
[0]Low power Cmd => 0xb5
[0]Low power Cmd => 0xb7
[0]Low power Cmd => 0xb8
[0]Low power Cmd => 0xbb
[0]Low power Cmd => 0xbc
[0]Low power Cmd => 0xc1
[0]Low power Cmd => 0xc2
[0]Low power Cmd => 0xd0
[1]Low power Cmd => 0xe0
[1]Low power Cmd => 0xe1
[1]Low power Cmd => 0xe2
[1]Low power Cmd => 0xe3
[1]Low power Cmd => 0xe4
[1]Low power Cmd => 0xe5
[1]Low power Cmd => 0xe6
[1]Low power Cmd => 0xe7
[1]Low power Cmd => 0xe8
[1]Low power Cmd => 0xeb
[1]Low power Cmd => 0xec
[1]Low power Cmd => 0xed
[1]Low power Cmd => 0xef
[0]Low power Cmd => 0xe6
[0]Low power Cmd => 0x3a
[0]Low power Cmd => 0x29
ERR:dispdev_openIFDsi() uiHBPByteCount = 349 MUST be 4x number
ERR:System_OnStrgInit_PS() PStore uiBufSize=262144
Третий блок ошибок:
Код:
ERR:GSensor_I2C_Transmit() i2c ret = 2!!
ERR:GSensor_I2C_ReadReg() Error transmit data1!!
[2021/11/05 20:53:04]ERR:GSensor_I2C_Transmit() i2c ret = 2!!
GSensor_open: SC7A30E ulData1 = 0x11
Четвертый блок ошибок:
Код:
ERR:AlgGetUIInfo() Error IPL Id = 0xffffffff
ERR:IPL_AlgSetUIInfo() Id: -1, SelIdx = 1126236193 error
Пятый блок ошибок (тут предупреждений, а не ошибок):
Код:
===================================== sensor display [MASK=00000001]->[MASK=00000003]
WRN:System_OnSensorDisplay() dual sensor, but ImagePipe is not enabled, ignore!
Шестой блок ошибок
Код:
ERR:SetupExe_OnPowerOff() Error parameter (1) with SetupExe_OnPowerOff
[EDOG]Read UIINFO
[EDOG]Read UIRES
ERR:idec_setVideoWinAttrEx() Vertical Scaling down ratio over 2!
Седьмой блок ошибок (предупреждений):
Код:
WRN:FileSys_WaitFinishEx() FileSys_Init not ready
WRN:FileSys_GetDiskInfoEx() FileSys_Init not ready
[2021/11/05 20:53:05]WRN:FileSys_WaitFinishEx() FileSys_Init not ready
[2021/11/05 20:53:06]WRN:FileSys_WaitFinishEx() FileSys_Init not ready
[2021/11/05 20:53:07]GxPower: Stop low-battery check.
GxPower: Start to Charge Battery
Восьмой блок ошибок:
Код:
UART4: Open success
ERR:FST_CMDGetFileLen() File not found
ERR: System_SetSSID 0
Character length error.
ERR: System_SetPASSPHRASE 0
Девятый блок ошибок:
Код:
ConfigMovieSizeOption:29
ERR:TM_SetOptionStatus() OptionIndex 25-25 too large
ERR:TM_SetOptionStatus() OptionIndex 26-25 too large
ERR:TM_SetOptionStatus() OptionIndex 27-25 too large
ERR:TM_SetOptionStatus() OptionIndex 28-25 too large
Десятый блок ошибок:
Код:
WRN:MovieExe_OnMovieSize() should change mode
SetH264MaxQp[0]=2
SetH264MaxQp[1]=2
MovieFile: Photo folder PHOTO
ERR:Note_Ae_Init() AE Table 1 is not support.
ERR:Note_Ae_Init() AE Table 5 is not support.
ERR:ChgMode_IMX291M() ChgMode_IMX291M to 1...
ERR:ChgMode_IMX291M() ChgMode_IMX291M End!!
[2021/11/05 20:53:08]ADAS LIB FSIZE = 100
Disable ImeParms!!
ERR:InitHough() POWERON_FAST_CPU2_BOOT not enable
Одиннадцатый блок ошибок:
Код:
===Movie Rec Set Vol = 100
PhotoExe_OnEV(): 6
ERR:fs_remove() A:\AXPER.BIN is not exist
ERR:fs_remove() A:\LDAXPER.BIN is not exist
ERR:UnInitHough() POWERON_FAST_CPU2_BOOT not enable
auto vp is already uninitial
ERR: [AXPER] g_uiWndMovieRecordFirst = 0
ERR: [AXPER] Set g_uiWndMovieRecordFirst FALSE_3
Mode {MOVIE} Open end
On Boot end
ERR:idec_setOsdWinAttrEx() Vertical Scaling down ratio over 2!
Двенадцатый блок ошибок:
Код:
ERR: [AXPER] AC is plugged, GPIOMap_DetAC = 1
  NO Battery, Ignore START
ERR: [EDOG] FileVer:2510,g_FiledTotal:50605,AXPER_25102021
[2021/11/05 20:58:07]USB Unplug
[2021/11/05 20:58:08]ERR: [AXPER] AC is unplugged, GPIOMap_DetAC = 0
ERR: [EDOG]g_EDOtherSoundId:94
On Shutdown begin
Mode {MOVIE} Close begin
SMediaRec_Close
Mode {MOVIE} Close end
ERR: System_OnShutdown---3
[2021/11/05 20:58:09]WRN:Ux_GetFocusedWindowWithIndex() Failed
Что тут значит NO Battery, Ignore START?
Вообще почему так много ошибок?
Что это за ошибки?
Как их исправить?
Val12
Одесса
Axper combo hybrid 2ch
Audi Q5
Всем привет!
Первый блок ошибок:
Код:
Второй блок ошибок:
Код:
Третий блок ошибок:
Код:
Код:
Код:
Шестой блок ошибок
Код:
[EDOG]Read UIINFO
[EDOG]Read UIRES
Код:
Код:
UART4: Open success
Код:
Код:
SetH264MaxQp[0]=2
SetH264MaxQp[1]=2
Disable ImeParms!!
Код:
PhotoExe_OnEV(): 6
On Boot end
Код:
On Shutdown begin
SMediaRec_Close
Что это за ошибки?
Как их исправить?
Датчик удара выключили?
Длительность файла 1 мин
Отформатируйте карту
kop4ik
axper combo hybrid wi
mazda 6
Всем доброго дня! Как только не пробовал, не получается сделать полностью беззвучный режим, все настройки перелопатил, все равно звучит звоночек и голос оповещает, что "пройдено". Это глюк прошивки? Причем и на старой прошивке было и на бета тоже самое.
Val-odessa
Одесская
Встроен в комбо устройство
Ауди
Добрый день, axper combo hybryd 2 ch wifi, кто знает, почему задняя камера отображается и пишется в перевернутом виде? Пробовал включать/выключать "поворот задней камеры" - без изменений.
Появилось после загрузки последнего обновления 23082022. Похоже необходимо вернуться к заводским настройкам?
Val-odessa
Одесская
Ауди
На оф. сайте такого нет. Может поделитесь файлами?
Добрый день,
Спасибо за ответ.
Подскажите как достать файл обновления, я его скачивал через программу в телефоне, там просто написан размер и дата, скриншоты прилагаю.
Поиск выдал такие папки программы, может подскажете где хранятся файлы обновлений?
Val-odessa
Одесская
Ауди
Добрый день,
Спасибо за ответ.
Еще вопрос: не подскажите, как отключить звук в устройстве? Очень громко оповещает что "спутники найдены", и часто радар пищит на протяжении 1-2 км
Если бы у меня был смартфон, то я бы смог ответить на этот вопрос. Да и, резонно, что сам смог бы эти файлы выцепить... :) А судя по внешнему виду - вероятно, в каталоге FWBin лежат файлы с прошивкой.
По звуку - не знаю. Достану из коробочки этот аппарат, посмотрю. А то лежит в коллекции (на продажу), я им пользовался очень малое время.
Val-odessa
Одесская
Ауди
Уточните: отключить звук совсем, вообще везде, или где-то частично?
Можно совсем отключить. Так как прибор реагирует только на камеры/радары по РФ, и в любой другой стране это просто видеорегистратор, то пусть просто пишет видео, в полной тишине
Val-odessa
Одесская
Ауди
С задней камерой явно что то не так. Картинка на мониторе перевернута и не реагирует на настройки "переворот задней камеры вкл/выкл". На видео соответственно вверх ногами. Перезагрузка не помогает. Кто может помочь советом?
@Val-odessa, увы, если не помогает установка громкости на ноль - то никак. Только если разобоать и отключить динамик, очевидно.
Vlendy
Нижний Новгород
BB Radar Plus
SY Kyron
Здравствуйте. Вообще по ходу сырое обновление 31.08.2022. История такая. Имею два регистратора, Axper Combo Hybrid/ один с вай-фай, второй без. С тем, который с вай-фай проблем нет, прошивка обновилась, все работает. На втором все было хорошо до обновления прошивки. С флешки родная прошивка ставиться не захотела, поставилась только после переименования в прошивку от вай-фай (c axpernw.bin в axper.bin). Все установилось, но стал очень плохо работать GPS, за поездку мог не найти спутников вообще. Ставил и прошивку от вай-файного регистратора — то же самое. Тот, что с вай-фай работает отлично. Думал может дело в GPS приемнике. Поменял их местами. Регистратор с Вай-фай работает нормально, значит дело не в приемнике. Регистратор без вай-фая тоже заработал, но спутники ищет достаточно долго. Задал вопрос в техподдержку - может ли быть дело в прошивке? Получил странный ответ: "После обновления ПО регистратор может и будет работать некорректно. Дистанционно определить, что теперь делать, не представляется возможным." в общем послали, обратитесь в сервисный центр. А так как рег не на гарантии, то думаю все манипуляции будут платными. И к старой прошивке не вернуться, под нее нет обновления баз камер. Вот такая грамотная техподдержка.
Neoline 6200s 16/11
А у меня с WiFi заглючил - стал ругаться на карту памяти (которая оказалась действительно уставшей), замена карты не очень помогла, за 20-30 минут спутники на окне отказывался находить и начинала ругаться уже на новую карту. Не с первого раза, но удалось обновиться на прошивку 31.08.2022 - спутники на столе нашёл через пять минут, 12 часов пробной записи в помещении прошло нормально.
Нет бесплатного обновления баз, насколько я знаю, на Ежедневное альтернативное обновление радар-детекторов и комбо-устройств сейчас выдаются базы именно под старую (2020 года) прошивку.
kalinindk
Ydmurtia
Axper combo
Reno sandero
Набор прошивок для Акспер с Wi-Fi.rar
Не открывается
Vlendy
Нижний Новгород
BB Radar Plus
SY Kyron
Ну да, но там 2400 рублей в год - как то не хочется платить за косяки прошивки от производителя.
Сегодня замерял с холодного старта - устройство с вай-фай ищет спутники около 2х минут, без вай-фая - около 6 минут. И это на не родных (т.е. не на тех, с которыми покупались, а наоборот) модулях GPS. На родном модуле регистратор без вай-фая вообще может за поездку длительностью в час спутники не найти.
Neoline 6200s 16/11
Мне 800р. предлагает, но соглашусь, что заплатив 15т.р. за устройство хочется получить заявленную продавцом бесплатную поддержку.
В моём варианте тоже покупной модуль - по глупости комплектный сломал. :(
garec
