V 1 ложные срабатывания
ag70
Great Wall Safe
Приглушенние в настройках включается для К-диапазона. Дословно по инструкции для настройки автоматического приглушения:
This section allows you to switch on a feature that automatically mutes K-band alerts under certain circumstances. Feature Characters b, C, d, E and G set the specifications of those circumstaces. This automating muting will happen in l and L modes only.
Как следует из этого, на лазер это не распространяется.
v1
Escort 9500ix RU, V1
Audi A6
ag70, опция F тоже относится к автоприглушению для C/O (Constant On).
ag70
Great Wall Safe
Да, относится, но не к лазеру. Это опция позволяет выбрать, приглушать ли звук при достижении 6 делений или нет
v1
Audi A6
Немного сложнее:
Options "E" and "F":
Option "E" controls the behaviour of muting upon FIRST ENCOUNTER of a K band signal.
With "E" set to factory default (UP ARROW), the initial encounter of a K band signal will be muted if less than 4 lights and unmuted if 4 or greater lights.
With "E" set to DOWN ARROW, the "unmute at 4 lights upon initial encounter of a K band signal" will be disabled and the signal must now be larger than 6 lights to break mute.
Option "F" controls the behaviour of muting after the FIRST ENCOUNTER of a K band signal.
With "F" set to factory default (UP ARROW), a K band signal that was less than 4 lights at first encounter and rises to 6 lights or greater within the time period defined by "b","C" and "d" options, will unmute.
With "F" set to DOWN ARROW, a K band signal whose initial encounter was below 4 lights will not unmute, no matter how many lights, until the time period defined by "b","C" and "d" has elapsed.
With both "E" and "F" set to DOWN ARROW, a K band signal will stay muted, no matter how many lights, until the time period defined by "b", "C" and "d" has elapsed.
ag70
Great Wall Safe
Да, просто привязано еще и к Е. Если E и F стрелкой вниз - то даже при достижении 6 делений будет молчать. Но если E вверх, то при достижении 4 делений начнет пищать, и не важно уже, как стоит F. Вроде так :) Еще и G нужно не забывать ставить стрелку вниз, иначе когда проезжаешь помеху и она излучает сзади, то начнет пищать.
v1
Audi A6
будет приглушенный до истечения времени, установленного опциями b, C, d.
Если E вверх и начальный уровень сигнала при сработке меньше 4, то звук сразу приглушенный. Если начальный уровень сигнала больше, то приглушения не будет, сразу громко.
Опция E контролирует приглушение при появлении сигнала, а опция F приглушение при дальнейшем повышении его уровня.
Эта опция всегда приглушает сигнал сзади, т.е. он в любом случае будет слышен на приглушенном уровне.
ag70
Great Wall Safe
Приглушенный звук или молчание определяет режим маленькой или большой L, а не эти параметры. Параметры задают только порог. В режиме маленькой L будет звук приглушенный до установленного уровня регулятором Mute, при этом не важно идет сигнал спереди или сзади, а в режиме большой L будет до установленного этими опциями уровня просто молчать, опять же не важно с какой стороны сигнал идет. Вы видимо еще не разобрались с различиями двух L-режимов.
v1
Audi A6
Я везде имел в виду только режим маленькое l. В большом L мало кто ездит и я тоже не советую его использовать, т.к. он не дает никакой индикации. Насчет "не разобрался" - учитывая, что я прочел все темы по V1 на radardetector.net, думаю, что разобрался.
ag70
Great Wall Safe
Я езжу в большом L по городу, очень удобно, не грузит почти. Все визири и фены отрабатывает отлично.
v1
Audi A6
А я предпочитаю в l, но с тихим приглушенным звуком. А какие у Вас опции выключены (down arrow) ?
ag70
Great Wall Safe
Если по опциям - то 1-2-3-4 все включены, 5вверх, 6 вверх, 7вниз, 8 вверх, А вверх, b вниз, C и d вверх, Е вверх, F вверх, G вниз, H вверх, J вверх, оба U вверх
v1
Audi A6
Тогда понятно почему Вы ездите в L: E и F включены. Я пока остановился на E вниз и F вверх. G и b,C,d у меня установлены аналогично. Надо голосование тут сделать - кого больше с каким опциями :)
bao-rope
Питер
ShoMe G-700STR
Аут
Почти гарантированно срабатывает на встречные инфинити в лазерном диапазоне(к фарам отношение не имеет, т.к. половину из них видел едущих без фар)
AndreyK
Cobra 945CT
Hummer H3 Alpha
Пару дней тестировал на Новой Риге. Москва-Истра - Москва. Срабатывает на все, что можно. Про двери я не говорю. На трассе стрелки мигают в разные стороны. Думаю, что от фур. Я очень не доволен результатом. И не надо рассказывать байки про то, что помехозащищенность у В1 на уровне. Старый Кранч 2190 был не хуже. Стрелки, это конечно "фан", но на.. он мне нужен, если они практически постоянно мигают в разные стороны.
На Новой Риге по направлению в Москву перед Мэйжер Сити есть стационарный радар. Старый Кранч берет его с 300-400 метров. Сегодня поставил на торпеду В1 и Кранч. Кранч, как всегда отреагировал, В1 молчал.
Фанаты В1 - обращение к Вам - купите новый В1 за 15 тыс. руб и будьте счастливы! Мое объявление о продаже в соответствующем разделе.
ag70
Great Wall Safe
Не стоит так горячиться. Его можно настроить и в L-режиме он будет тихий как кранч :)
AndreyK, и слава богу! Читать Ваши инсинуации на всех страницах и разных форумах грустно и утомительно, объяснить как настроить и получать удовольствие невозможно.
Каждому свое, Кранч - Ваш ДР. Ну и ладушки :)
keicy
Valentine One
Audi A6 Avant Quattro
AndreyK, а я тестировал Москва-Шаховская-Москва... были редкие сработки на автоматические двери... Стационарные два радара я так понимаю то включены то выключены, так как В1 то срабатывает, то молчит.... на что сработал кранч - одному ему известно... возможно на двери как раз...
Едем в сторону МСК, участок ни одной АЗС нет, вдруг сработка на 3-4 деления на 5 секунд... И тишина... Едем дальше... через километр опять сработка, те же 5 секунд, но чуть мощнее... И опять тишина... через километр опять сработка, еще более мощная... еще через два сработка на полную шкалу... Под мостом стоит гаишная 14я, рядом инспектор с радаром в руке, второй уже окучивает авто... от первой сработки до гайцев - 4 км (!)... Валентайн - ты лучший *BRAVO**BRAVO**BRAVO*
AndreyK
Cobra 945CT
Hummer H3 Alpha
Я не спорю! Берет он далеко. Но у меня он По Новой Риге сильно орал и практически на все проезжающие мимо автомобили и фуры. Может просто так "повезло". Одним словом, попробую Бел 65, попробую Эскорт и тогда приму решение. Может и В1 опять закажу, если у двух других результат по ложной сработке будет не лучше.
keicy
Valentine One
Это как должно было "повезти"? я часто езжу по новой риге, и никогда V1 не орал на все подряд... Как и у многих других владельцев...
Если ваша цель - продать V1, так и продавайте себе спокойно, только зачем его хаять при этом?
Работал в режиме all bogeys, звук стоял на минимуме, то есть беззвучно. Визуальных индикаторов вполне достаточно.
markiz050
Valentine One
BMW
Очень интересная и креативная версия продвижения своих товаров на рынке! Молодца...:D:D:D
SpeedRacer
