- Регистрация
- 16.05.2011
- Сообщения
- 11 293
- Реакции
- 3 837
- Регион
- Около Москвы
- Детектор
- V1
- Авто
- X-Trail
Мне тут письмо пришло от V1 :
Кто может проверить эту возможность фильтровать ?
Here's the problem: K-band false alarms--which were merely nuisances back when automatic store-door openers were the most common source--have recently become major-league irritants, both in their frequency and their persistence.
What changed? A safety feature that's becoming common on new cars--the lane-change, or blind-spot, warning systems--often use weak K-band radar to "see" other vehicles nearby.
The door-opener problem was self-limiting--it was stationary and you soon drove out of range. But you may be driving in a pack with a blind-spot system, and you're stuck there for miles, not knowing which is the offending car so you don't know which one to maneuver away from.
V1 responds. If your V1's serial number ends in 1179 or higher, you already have our best solution built into your detector. It's a software revision we call the Junk-K Fighter, created to exclude mobile sources of unthreatening K signals. You need only to activate it.
How to activate this feature.The Junk-K Fighter is paired with another software feature, Traffic Monitor Filter, and they both turn on with the same software switch.
For older V1s, the Junk-K Fighter is included in our latestUpgrade
LINKS:
How to activate Traffic Monitor Filter and Junk-K Fighter from V1's front panel (animation): TMF and Junk-K Fighter activation
How to activate Traffic Monitor Filter and Junk-K Fighter (Written step-by-step instruction: Tech Report 3
How to Customize V1 against Junk-K signals using your smartphone—this requires V1connection, an optional Bluetooth module available from us, and a free app called V1Connection, the app, available from your app store. (Android / iPhone)
